fuser nip dc5252
  • davidj7
    • 1107
    fuser nip dc5252
    Hi,
    I adjusted the fuser nip of DC5252 to 4mm as per specifcation.
    The fuser nip measurement is fine now but I get creasing on all media except 220gsm onwards.
    I checked the fuser nip after 10mm on both ib and ob . I set both at 4mm since 4.1 and 4.2 are quite impossible. The 4mm is within the specification . Any way to make the creasing go away.
    thanks
    a machine is only as good as your tech : source:screwtape ; the scary one
  • xcopytech
    • Aug 2006
    • 1794
    did you check oil system
    maybe you have too much oil
    • Milo Wilson
      • 508
      What do you mean by creasing?
      • davidj7
        • 1107
        folds in the paper. i have to go by xcopytech's reply there is lots of oil comming into the machine. i have replaced 2 donor roller assy, 2 h rollers, oil pump, wick , excess oil flows out fine. grrrrrrrr
        • Milo Wilson
          • 508
          You will have to check the spring pad adjustment also. The same area as the nip adj. screws but the red ones instead. You have to remove the belt stripper finger assy to get to them. I would reference the edoc for proper adjustment on those.
          • xcopytech
            • Aug 2006
            • 1794
            too much oil with non xerox paper will result with paper creasing
            • davidj7
              • 1107
              all the papers were running fine before i did the nip adj 10.1
              • davidj7
                • 1107
                issue resolved
                • Milo Wilson
                  • 508
                  What was the problem? How did you take care of it?
