DC12 fade on edge (pic attached) need help, pls
  • JimmyB
    • Jun 2008
    • 77
    xerox dc12 fade in all color on whole side on trial edge. look at pic (sorry for low quality pics ).
    the fade is about 2-3 mm.
    i think the problem is in IBT assy, but do not have another one to change and check.
    any supposition? thanks
  • davidj7
    • 1107
    do a hard stop and see the image on the IBT assembly. If it has the same issue then you can be sure its with IBT.
    I had a similar issue long time back. I did fix it but how i dont remember .
    Do you have another DC12 nearby . you could just interchange IBT assy and confirm .
    a machine is only as good as your tech : source:screwtape ; the scary one
    • xcopytech
      • Aug 2006
      • 1792
      agree with davidj7, do a hard stop procedure to see image on drum and IBT.
      Also check first IBT roll.
      • JimmyB
        • Jun 2008
        • 77
        after hard stop image on IBT belt is faded ( the same as printed image).
        i replaced IBT assy, 2 btr and drum from working machine, but the problem remain.
        now, i will try with developer assy and ROS.
        • davidj7
          • 1107
          whats the size of paper you are using. If you have a 12x18 try that and tell me how much print area has faded or shows a colour difference.Secondly is there a sudden drop of colour from a particular area or does it comes down slowly.
          • JimmyB
            • Jun 2008
            • 77
            paper size is SRA3 (320x457mm) image size is 302x440 mm
            the faded area is about 2-3 mm in IB side on whole lenght (440mm)
            look at magnify pic: (the skew is from taken photo)
            no color drop, the fade look like as missing toner. colors of the pic is 100% cyan and 100% magenta
            • davidj7
              • 1107
              if you think a colour is missing print 100% c , m y k and check if any colour is missing
              • xcopytech
                • Aug 2006
                • 1792
                see attachment
                • JimmyB
                  • Jun 2008
                  • 77
                  when print 100% CMYK, all color missed and image fade is the same as one color print
                  xcopytech, about image size on SRA3 max image is 303x444 (look at bulletin: Expanded Image Area on the DC12 printer)
                  and on another dc12, on SRA3 paper, image size is exact 303x440 and on 12"x18" paper, image size is 298x450mm, on both sizes with no trouble of quality.
                  The DC12 Firmware version 11.50.3 enables an Expanded Image Area on to be printed on the printer.
                  The guaranteed imageable area is as follows:
                  - Print mode:
                  12 x 18" paper - 297mm (+2.0/-0.5mm) x 438 mm (+13.0/- 0.5mm)
                  SR A3 paper - 297mm (+6.0/-0.5mm) x 438 mm (+6.0/- 0.5mm)
                  • davidj7
                    • 1107
                    i think its problem with ros.
                    • kandod
                      • Mar 2010
                      • 58
                      I have a similar problem with the image fading slightly the last few centimeters IB, and the effect was to a some degree removed after cleaning the Erase Lamp surface, although it is still far from perfect.
                      • JimmyB
                        • Jun 2008
                        • 77
                        thanks for all mates.
                        after playing with Lead / Side Registration and ROS DELETION NVM, now fade disappear .......
                        xcopytech and davidj7, do you know anything about skew of image for DC12. how to correct skew?
                        • xcopytech
                          • Aug 2006
                          • 1792
                          how big is skew?
                          only way which I know is to adjust registration assy.
                          • davidj7
                            • 1107
                            is the skew present in all trays 1-4 or tray 5. and as xcoptech asked . how big is the skew
                            • GusG
                              • Jul 2008
                              • 198
                              Hi JimmyB, I've also got a fade much like yours and I'm curious to know how you played with Lead / Side Registration and ROS DELETION NVM? I've cleaned the Erase Lamp surface but that didn't do anything
