Problem: Xerox 510dp dumping developer, Code or error 3 when doing electrostatics 09-04.
I have swapped drum, developer housing, charge and transfer/detact assembly from a working 8850, all ground wires/contacts are in place. What else should I check?
Also I have a xerox 8830 that when turned on the controll panel flashes a LL-55 code then
some other numbers back and forth, can't go into diagnostics.
So I'm down to just my 8850, any help would be appreciated.
