Xerox workcenter 7232
  • Clarke
    • Jun 2025
    [Error Code] Xerox workcenter 7232
    I ve got a xerox workcenter 7232 that is giving me error 061 325.plse can you help
  • Goshe
    • Jul 2009
    • 118
    The light intensity of LD2 doesn't reach specified value. check connections p/j401 on mcu pwb and p/j140 on ros unit. If it is ok, check the wires between j401 and j140 for short or open circuit. if the wires are ok, you should replace ros unit.
    • Clarke
      Thanks.will try that
      • yomba
        • Jul 2012
        • 37
        Re: Xerox workcenter 7232
        Are there any settings
        to change in the service mode after you replace the ROS ?
        • yomba
          • Jul 2012
          • 37
          When you replace the ROS what NVM settings do change ?
          • wtroll
            • May 2008
            • 85
            Nothing else to do, only check print & copy quality.
            • yomba
              • Jul 2012
              • 37
              The copy/print quality is poor.
