Xerox WC Pro 245 - OF3 Dead Machine RAP
  • dinkyoaf
    • Sep 2010
    • 63
    [Dead] Xerox WC Pro 245 - OF3 Dead Machine RAP
    Xerox WorkCentre Pro 245:
    You can power it on, the lights to the right of the display will come on, then everything shuts off.
    Service manual says: "Go to the OF3 Dead Machine RAP"
    OF3 Dead Machine RAP does not exist. I cannot find it anywhere.
    Can anyone shed any light on this?
  • xeroxsharp
    • Nov 2008
    • 270
    UI PWB,LVPS
    • dinkyoaf
      • Sep 2010
      • 63
      Originally posted by xeroxsharp
      UI PWB,LVPS
      We already replaced both of those and the issue is still occurring. Thanks for your input, though.
      • Milo Wilson
        • 503
        Make sure the hard drive in the controller is connected ( data and power ).
        • TzALbg
          • Dec 2007
          • 111
          try replacing NVM module or upload MBR nvm
          • CopierTechofOmens
            Agitating Artificer
            • 268
            I would run through the 01J RAP.
            sigpic
            • dinkyoaf
              • Sep 2010
              • 63
              Well the tech never got back to me about this so I'm not sure if anything worked. Thanks for the help everyone!
              • amadeusmbi
                • 51
                Normaly is a LVPS problem, but if you replace LVPS and the problem still there then you have to replace HVPS also and verify UI PWB (can make your hell life...). When is NVM the machine is booting but with speed/drum/fuser error. Then you need to replace battery and reload NVM.
                Good luck!
                "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
                • dinkyoaf
                  • Sep 2010
                  • 63
                  Good luck!
                  Thanks!!
                  • arjun
                    Re: Xerox WC Pro 245 - OF3 Dead Machine RAP
                    Hi , I having same issue with my XEROX WC Pro 245 from today morning , while booting i heard little sound like "thud" and then it went down, after switching on again , Green led's beside LCD comes up and within 10 seconds complete machine shuts down.I doubt some fuse may have been blown.Please let me know where can i check for fuses..?
                    Kindly help me with service manual.
                    Thanks in Advance.
