DC700 Unfused print Inboard
+ More Options
Posts
  • ktxerox
    • Mar 2009
    • 229
    HI All,
    i am facing problem in DC700 on 260GSM paper unfused from inboard on havy ground or full ground prints. problem is only coming on 260 GSM or Above 260 GSM . copy and print both haveing same issue. try to change settings coated , uncoated but same problem. is anyone have same issue ?
    reg
    kt
  • kalindd
    • Jun 2008
    • 192
    What is SW level?
    • ktxerox
      • Mar 2009
      • 229
      Don't know right now exact but its new machine just installed 1 month ago.
      • kalindd
        • Jun 2008
        • 192
        Sw level for this problem very imprortant. It enables the half latch fuser. It need to be V3.1.
        • ktxerox
          • Mar 2009
          • 229
          hi kalin,
          today i try to change the nvm velues as per your instructions 744-699 is already on 46 but 744-709 is not access able msg is can not be access at this time. please see the SW bellow.
          system sw v 5.3.1
          controller rom v 1.2.211.0
          IOT rom v 54.37.0
          HCF rom v 3.23.0
          finisher D Rom 4.8.0
          IFM rom 7.14.0
          IIT rom 2.4.1
          ADF Rom 12.0.3
          SJFI 3.0.12
          SSMI 1.11.0
          What to do now ?
          • ktxerox
            • Mar 2009
            • 229
            HI All,
            i am still stuck can any one help me ?
            • RockETop
              Curmudgeon at large
              • Apr 2007
              • 171
              You have sw version v3.0, v3.1 will have IOT version at 54.42.0 Upgrade to v3.1 and your problems should go away.
              • kalindd
                • Jun 2008
                • 192
                Have you tried lowering the NVM values that I sent you?
                Even without 54.42.0 you can fix this problem with those NVMs.
                Like I did this 3 days ago.
                • ktxerox
                  • Mar 2009
                  • 229
                  HI,
                  Dear kalindd you are right problem has been fixed to change these nvm velues. meanwhile there is also have iot software update patch to resolve this issue and one 3 nvm velues.
                  thanks to all for this help.
                  reg
                  kt
                  • kalindd
                    • Jun 2008
                    • 192
                    The patch you are talking about is "Fuser gloss mode" maybe, am I right?
                    Enabling the fuser gloss mode its not a fix for your problem, it's more like a workaround.
                    Some customers don't like a glossy finish.
                    Anyway it's good that everything is fine now.
                    Good luck
                    • amadeusmbi
                      • 51
                      Change media (paper). Try RML or try at least 3-4 type (different brands!) of 260gms (coated or uncoated).
                      "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
                      • ktxerox
                        • Mar 2009
                        • 229
                        yes you are right patch is for fuser gloss mode and also for to resolve this issue there are 3 nvm velues those need to be change. it is havyweight paper mode software procedure for v3.0
                        where from u r ?
