Xerox workcentre 7132
  • screwdriver08
    • Jul 2010
    • 160
    [Jamming] Xerox workcentre 7132
    AFTER ONE OR TWO COPIES MY XEROX WC 7132 KEEPS SAYING THAT THERE IS A JAM AT LEFT SIDE TRAY "A" (where it opens up to the Fuser) and SIDE TRAY "B" (paper path). AND THE THERE IS NEVER A PAPER JAMMED IN THERE WHEN I OPEN IT. AFTER CLOSING THE TRAY, IT WILL ALLOW ME TO PRINT AGAIN..BUT THE JAM PROBLEM SHOWS UP AFTER ONE OR TWO MORE COPIES. IT HAS BEEN DOING THIS FOR QUITE SOME TIME. ANYONE KNOW WHAT I SHOULD DO? OR HOW I CAN SOLVE THIS PROBLEM?
    THANKS
  • elsab
    • Dec 2007
    • 63
    static jam, try initialize iot nvm
    • screwdriver08
      • Jul 2010
      • 160
      Elsab,
      How do I do that?
      Step by step if you can...
      • elsab
        • Dec 2007
        • 63
        not so familiar with 7132, but usually xerox products has the same diagnostic/ ce mode. to enter ce mode, press and hold "0" button for 8 sec. then press start.
        log in, then navigate to find iot nvm initialization. try it.
        • screwdriver08
          • Jul 2010
          • 160
          it worked, pressing 0 for 8seconds then pressing start. am here at the NVM intialization, now what do I do...sorry for too many questions but this is the second time I have worked on this type of machine.
          • elsab
            • Dec 2007
            • 63
            tick iot nvm initialization only then enter.
            then restart the machine.
            • amadeusmbi
              • 51
              What error code? (left/down screen, xxx-xxx, like 077-123 or something)
              May be the registration clutch... give us a code.
              "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
              • elsab
                • Dec 2007
                • 63
                your might be right amadeusmbi, but unique problem like above encountered might be a problem on unstable nvm value. have screwdriver08 tried to check fuser exit sensor or inverter swicth for this matter also?
                • screwdriver08
                  • Jul 2010
                  • 160
                  What does this mean?
                  Execute Component Control [077-105 Fuser Exit Sensor]. Manually activate the actuator of the Fuser Exit Sensor (PL 7.1).
                  The display changes.
                  Or how do I do that? through the UI diagnostics mode?
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
                    Paul@justmanuals.com
                    • amadeusmbi
                      • 51
                      ok, have you try from MPT (Manual Paper Tray; clean feed roll, it may be dirty)? same problems? I have many of this xerox type and never have NVM problem with this error. Usually is a hardware problem. Paper picked up from tray?
                      Good luck!
                      • screwdriver08
                        • Jul 2010
                        • 160
                        I turned on the copier today and the first thing that happened is "Paper Jam" and I have not even made a copy or printed anything.
                        • screwdriver08
                          • Jul 2010
                          • 160
                          Re: Xerox workcentre 7132
                          my workcentre 7132 tells me that i need to replace the "transfer belt cleaner [r2] smart kit", i looked for it online and could not find it, i looked at the wc 7132 service manual and i still cannot find that part, however i did find a "ibt belt cleaner", is that the same thing?
                          • Milo Wilson
                            • 503
                            Yes it is the same
