Colour misregistration on DC3535
  • GusG
    • 198
    I have an odd situation where my DC3535 prints perfectly well in normal/bond mode (even when I print to heavier papers in that mode) but when I try to print any of the heavyweight modes (heavyweight/coated 1/coated 2 etc) I have a massive problem with yellow registration that is off by 2-3mm in the print direction.
    Any clues on this one?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Colour misregistration on DC3535
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • maich4s
      • Mar 2009
      • 86
      try see if there are patches ad software updates for this,atlease for phaser7760 there are some patches.
      • GusG
        • 198
        Paul, I bought the manual from you already.
        I also have a PWS and with neither can I get anywhere, doing regicon comes up with NG results
        • GusG
          • 198
          Will have a look for patches
          • GusG
            • 198
            Downloaded and installed a general patch that's supposed to fix a lot of issues but it didn't do anything for me, doesn't look like any of the others available will sort this out.
            There is a Fiery system software version 1.1P, I already have 1.1 (without the P) and I wonder if there is anything for me to gain by getting the 1.1P
            • xcopytech
              • Aug 2006
              • 1793
              If you perform color registration from PWS and get NG result, then fiery patch will not help you.
              Try to perform procedure from service manual for color registration.
              • GusG
                • 198
                Hi xcopytech,
                Do you mean the procedure for turning the adjustment screws on the ROS as outlined in DC685 (adjustment 9.6)?
                If so, we've done that and, as I mentioned, if I print to "normal/bond" the registration is perfect, even printing on 135gsm artpaper using the "Bond S" setting. Only when we use heavyweight 1 or 2 or coated 1 or 2 do we get the issue.
