A_Tech
  • Alexx
    • Jul 2025
    A_Tech
    Is anybody knows how adjust density on top of copies. My Xerox 5352 makes black lines about 0.5-1" from top of the page on standard density setting. Does Xerox has some kind of setup service screen, where I can adjust density on edges like on other machines? All glass and mirrors are clean. Thaks for help.
  • xcopytech
    • Aug 2006
    • 1794
    xerox 5352
    hi,
    i have not seen this old guy for long time.
    i will check in old service manuals and will inform you.
    br
    • Alexx
      Xerox 5352
      Thanks, any information will help.
      • Alexx
        Xerox 5352
        Looks like you didn't find anything, ha...
        • Alexx
          Xerox 5352
          Trying to find service manual for Xerox 5352. I know it is old machine and service it without manual it's like walking in the forest at night...
          • Polo-022
            • Sep 2007
            • 486
            There is no density adj. on top edge or lead edge,on any copier!!!
            I guess you have to clean E.R.U scorotron for this problem.
            • Alexx
              Xerox 5352
              Thanks for help, I will try to clean that. Also recently I had another problem.
              When I run a clear sheet even in very light density, I have light grey copy out instead clear white. I is all over a page. I wish I know how change density programmable, so I can set it level down, if my Xerox has that function.
              Thanks for help.
              • Polo-022
                • Sep 2007
                • 486
                You mean background all over the page? If so, try to localize if it is an exposure problem (low exposure) or development (high toner dispensing).
                • Alexx
                  Xerox 5352
                  Unfortunately I'm not a pro, but I think it is something with exposure. It does grey background when set to autoexposure or higher, but when I set it to very low, copies are fine. I have this problem only about a month. I don't know what to do. If I had a service manual, I would figure out, but now I'm only hoping on your guys help.
                  • Polo-022
                    • Sep 2007
                    • 486
                    Did you clean charge scorotron? Any result?
                    May be drum life is over. Do you have the same c.q on a long copy run or differs from copy to copy? If drum exceeds its life-over 250K-these are the symptoms you describe above. (Can you swap E.R.U with a good one?) As for the S.M or copy quality adj. on this model i think its very complicated for someone who doesn't work on Xerox analog models. I wish i could help more!
                    • JRCS
                      • 43
                      Xerox 5352
                      If I remember right the drs (Distance between mag roller and drum) is not even, you have to replace the developer housing shoes (Little brown half moon plastic type thing), they sit where drum and developer housing touch each other, and then you have to set up (calibrate the ADC sensor.
                      Good luck!!!
                      JRCS
