Error Code 124-314 + Technical Question
  • chrisoverson
    • Nov 2012
    • 25
    If anybody has any ideas that might help, or know how I could salvage the printer, I'd happily help in return by offering programmed backup EEPROM chips for these printers which could restore these settings if anything ever went wrong. I can easily change the product number and serial to match any printer upon request. I'd only ask enough to cover my costs.
    Thank you in advance to anyone who might be able to help, this is really important to get working again as I'm sure you can understand.
  • chrisoverson
    • Nov 2012
    • 25
    Re: Error Code 124-314 + Technical Question
    Oh, thought I should add that I tried to do the "Forced NVM Initialization" by holding down Stop, Power Save and 3, but it didn't seem to do anything - I'm not sure if I did it right. By Stop does it mean suspend? (the button above start). I could successfully get it into Download Mode so I wondered what the problem was here...
    • Milo Wilson
      • 502
      The only way to fix this is to get Xerox to reprogram the boards with the correct serial number. Sorry.
      • chrisoverson
        • Nov 2012
        • 25
        Thanks for the reply. I can program the EEPROM with the correct serial number myself, it's just that I can't correct the IOT speed fault. Any ideas there? Obviously the boards need more than just the serial numbers.
        • XeroxTechBrazil
          • Aug 2008
          • 198
          Do you have the old parts?
          If so, visit SearchLite doc # 708497 on your PWS for a possible resolution.
          If not, SearchLite doc # 708497 describes what has to be done if not recoverable.
          • chrisoverson
            • Nov 2012
            • 25
            Originally posted by XeroxTechBrazil
            Do you have the old parts? If so, visit SearchLite doc # 708497 on your PWS for a possible resolution. If not, SearchLite doc # 708497 describes what has to be done if not recoverable.
            I don't have the old parts unfortunately no, but I will definately check out that document. Thank you .
            • chrisoverson
              • Nov 2012
              • 25
              • chrisoverson
                • Nov 2012
                • 25
                Hi guys.
                Sorry to bump, but could anyone give me their value for 700-601 on a DocuColor 240/250?
                Thanks!
                • Milo Wilson
                  • 502
                  I'll look that up today but I am really interested in what you have done to program the chip.
                  • xcopytech
                    • Aug 2006
                    • 1794
                    dc 242
                    700-600 65020
                    700-601 65020
                    700-602 65020
                    • chrisoverson
                      • Nov 2012
                      • 25
                      Excellent, putting the setting 65020 into the EEPROM has made the IOT speed error disappear, thank you very much! .
                      Unfortunately I now have Error 116-312, so I'm trying to resolve that. Argh.
                      • chrisoverson
                        • Nov 2012
                        • 25
                        Okay, progress is being made.
                        I've got the printer up and running, but it is now not accepting connections over the network.
                        Does anybody know how to troubleshoot this problem? It does not respond to ping requests on 10.51.71.133 (this was its IP). Is there a default IP address that it might have changed to?
                        Thanks again! I've been typing up all my notes on how I've programmed this information and will share it when it's all up and running.
                        • xcopytech
                          • Aug 2006
                          • 1794
                          do you have a bustled fiery?
                          can you go to tools and check ip address?
                          • chrisoverson
                            • Nov 2012
                            • 25
                            Yes I believe I have a bustled Fiery.
                            Network scanning is greyed out, and network settings does not appear under admin settings... so I'm at a bit of a loss.
                            I've used a network scanning tool to ping all addresses between 10.51.71.0 and 10.51.71.255 but it doesn't show up.
                            Tried multiple reboots, blowing the dust out of the ethernet ports, but nothing seems to work.
                            If I connect a monitor to the Fiery all I get is "Uncompressing Linux.... Ok, booting the kernel" but nothing afterwards, no GUI.
                            I'd appreciate any help you can give me .
                            • xcopytech
                              • Aug 2006
                              • 1794
                              check NVM 790-402 is 5
