Module Xerographic WorkCentre Pro65
  • adriansto
    • 2387
    #31
    Re: Module Xerographic WorkCentre Pro65
    You CAN NOT use any 24Cxx chip with WCPro65. The machine NOT ACCEPT to talk with 24Cxx chip
    The WCPro65 accept only original xerox01 - xerox90 chip.
    • Enzo
      • Jul 2009
      • 413
      #32
      So I can only find a program that writes the original eprom xerox01 - xerox90! Damn!
      • Enzo
        • Jul 2009
        • 413
        #33
        Nothing programmer is able to reset the chip wcp65! It has the code: XC01 S/54SR. The sites indicate how bad chip!
        • Enzo
          • Jul 2009
          • 413
          #34
          I am able to write data on a chip. Now I have the data in a chip wcp65 already arrived to 60,000 copies. I can change (by particular software) the value of 60,000 and bring it back to 0?
          • KHALEDGAD77
            • Jan 2012
            • 11
            #35
            can u send me this program what akind of the epprom
            • KHALEDGAD77
              • Jan 2012
              • 11
              #36
              khaledgad77@yahoo.com
              • Enzo
                • Jul 2009
                • 413
                #37
                Hello friends. recently my WCP65 gives me this defect. (see attached)
                The Xerographic module is new, even the fuser is new. I noticed that the sheet gets dirty when it comes to the developer. but I clean it. What can it be?
                scan wcp65.pdf
                • Enzo
                  • Jul 2009
                  • 413
                  #38
                  Originally posted by hmelo
                  clean the doner roll in developer housing.
                  clean ros.
                  make a xerografics setup.
                  I've already done! I also put a new laser!
                  • Enzo
                    • Jul 2009
                    • 413
                    #39
                    Them You have a BAD xerografics module.
                    but I have 3 new xerographic modules and all of them have the same problem. is not possible!
                    • Enzo
                      • Jul 2009
                      • 413
                      #40
                      Unfortunately I have no other machines to test my modules. I have 4 new modules and they all do the same problem. I will try to better clean the developer.
                      • Enzo
                        • Jul 2009
                        • 413
                        #41
                        I opened it and clean the developer but the problem remains!
                        • Enzo
                          • Jul 2009
                          • 413
                          #42
                          hello friends. some technicians have told me that my problem to eliminate the copy shaded, need connect with PWS and run diagnostic. I have some programs and now the car showed me the message of "diagnostic starts." but I can not make it work. maybe I'm missing some program or not I can. can you tell me exactly what program is necessary and how it works? I have already managed to reload the software on the DC440st, I think that with your help I'll be able to do this for the wcp.
                          thanks
