Module Xerographic WorkCentre Pro65
  • Enzo
    • Jul 2009
    • 413
    Hello friends. I have a Xerox WorkCentre Pro65. I should buy the Xerographic module. The code that I use is: 113r623. Now I should buy an American module, with code: 113r621. I ask you ... I will have problems with compatibility?
    If the codes are not compatible between them, some of you can give me the data .bin to I reprogram the chip? thanks
  • Scarecrow
    • Oct 2010
    • 234
    Re: Module Xerographic WorkCentre Pro65
    Can you reprogram the cartridge chip? I have not been able to do it - seems to blow up. I was fortunate enough to buy a bunch of new fuser chips. You can rewire the fuser chip to fit the CC. We run a few copies on the chip for some reason - I just don't remember! I think we put about 50 copies on the chip when it's in the fuser, then rewire it. - Will let you know.
    • Enzo
      • Jul 2009
      • 413
      Obviously I reprogram a chip to third-parties! But I must have given the data .bin
      • Enzo
        • Jul 2009
        • 413
        Nobody has the .bin data for the fuser?
        • bojans
          • 1313
          I believe that I have .bin for fuser. Send me your e-mail address.
          ****These machines are peace of shit!****
          • Enzo
            • Jul 2009
            • 413
            My friend, I sent you my email. I hope you have also Xerographic Module .bin!
            • bojans
              • 1313
              Sorry I don't have it.
              But I never saw any of these modules reach it's life!!!
              As a matter of fact are we talking about WorkCentre Pro65 LAKES Family. It has Photoreceptor module!
              If yes I believe there is option in Diagnostic to prolong life.
              • Enzo
                • Jul 2009
                • 413
                Thank you very much my friend. You have done a lot for me.
                • bojans
                  • 1313
                  You're welcome
                  • Enzo
                    • Jul 2009
                    • 413
                    Well. Now the situation is this:
                    I took the data from the EEPROM module working who had worked 40,000 prints.
                    I put the data in a eeprom (24c02) virgin.
                    I soldered the eeprom on the circuit.
                    The machine does not recognize me the module!
                    In what I did wrong? I do the same operation on the xerox dc440 for 2 years and everything has always worked well!
                    • bojans
                      • 1313
                      You cannot use 24C02 EEPROM. Some machines can use that eeprom, but some first chech if there is xerox 01 chip.
                      • Enzo
                        • Jul 2009
                        • 413
                        The original eeprom is a Xerox 01. It is the same chip used in xerox dc440. That's why I used a eeprom 24c02 for xerox wcp65.
                        In your opinion, how can I fix it? I am using a programmer 24c02 I managed to get the data from the original chip (used with 40,000 copies).
                        • bojans
                          • 1313
                          As far as I know you'll need "special" software to write the chip!
                          And it must be xerox 01, not 24C02.
                          You can program some eeprom's, such as for 2240 and 2128 series by changing eeprom with 24c02 or writing xc01 with first 128 bits (set to 24c01).
                          Try to google Xerox 01, you'll find information how does it work.
                          • adriansto
                            • 2387
                            You can use original chip from new DC440 cartridge 113R00318 and rewrite it with the bin of Pro65 fuser or drum. But you need proper software for this operation
                            • Scarecrow
                              • Oct 2010
                              • 234
                              Get a new fuser for that machine, run a few copies - 25 - maybe, rewire the fuser crum to be exactly like the cc crum. Look carefully. On the 265 we have to add a wire and cut a trace. Done it several times.
                              Anyone know how to reprogram an OEM rfid crum? (123/128, etc.)
                              Glenn
