5655 Fuser Overheat Error
  • mrfuser
    • 1617
    We have replaced the fuser twice and it still is giving us odd fuser errors. Machine clicks, then says adjusting fuser temp. Works okay, just gives this message. Error log shows fuser overheat error. Is this a power supply going south?
    Thanks all!
    Kelly
  • Syrinxcs
    Re: 5655 Fuser Overheat Error
    I've had this happen before and i ended up replacing the power supply. Took care of it.
    • Exok
      • Jun 2011
      • 750
      What? a 56xx with a power supply problem? never!
      Just make sure you check the connector on the machine side for any bits of paper stuck there before trying a new power supply.
      • big mike
        • Sep 2012
        • 155
        The fuser triac is inside the power supply. If the fuser is good and the triac fails either 'fails on' or 'fails off' it will cause that problem.
