Xerox Docucolor 250 and 5000 Toner
  • alopezv
    • Jun 2025
    I recieve an info from a xerox tech that the toners inks of xerox docucolor 250 and 5000 are the same but are for different target and prices.
    I see the cartridge and the two are similar, the product price are similar too but the box for 5000 come with two toners this make the price half.
    Some have info abut this.
    Alfredo
  • alopezv
    • technic
      • May 2008
      • 29
      Actually that is the same question I have. The architecture for the Xerographic subsystem is the same for Dc250 and 5000, but I have been told that the 5000 uses oil in the fuser. The next week I will get some toner for 5000 and I will test it in DC250. If somebody knows any problem doing this, please let me know. If not I will let you know what happens...
      • xcopytech
        • Aug 2006
        • 1792
        Toner Is Not The Same
        • technic
          • May 2008
          • 29
          Thanks a lot Xcopytech.
          • will_mart
            Toner docucolor 5000 is similar with docucolor 8000.
            • davidj7
              • 1107
              5000 and 8000 toner is different. 2045/5252/2060 and 8000 toner is same
              • Milo Wilson
                • 499
                The toner for the 2045/2060/5252/6060/7000/8000 is exactly the same the only difference is that the 7000/8000 is chipped for usage. That keeps you from reusing the cartridges by refilling. I don't know about the 5000 toner being the same.
                • adeyemi
                  • 378
                  Pls be careful about this toner substitution business, i once ran out of DC252 toner and refilled with 2060....it seemed to work initially but after a short run i started getting paper badly jamming in the fuser, cos heat roll could not adequately melt the toner. I almost lost a fuser and had to change dev materials in the two dev modules i refilled, viz yel and mag in order to flush the xero system of the 2060 toner before the machine recovered.
                  Imperia and Pinhurst toner worked for my 252!!!....(free of charge):cool
                  Dgtal
                  • technic
                    • May 2008
                    • 29
                    • adeyemi
                      • 378
                      Imperia.....7228/35/45
                      Pinehurst...7328/35/45
                      Dgtal
                      • yosemitesame
                        is this a xerox machine? and what is the cost of these toner box
                        thanks
                        • xerotec
                          • Oct 2009
                          • 45
                          This is not same toner
                          DC2045/2060/5252/7000/8000 is same as DC5000
                          and
                          DC1632/2240/3535, WorkCentre C2128, WorkCentreM24 is same as DC250 DC252
                          i use this toner for 2 year and dont have any problems
                          • Caffeine
                            • 390
                            Re: Xerox Docucolor 250 and 5000 Toner
                            and
                            Actually, 1632/2240/3535 and M24 are EA toner, and are not the same as the C2128/7335 & DC250, which are EA-HG. But they are close enough that the only difference you will see is a very slight difference in the amount of gloss, and a very small amount of color balance variation. Both pretty minor. But, not the same. They are mechanically compatible, though, in as much as they won't cause problems for your machine like using the 5000/2045/2060 toner.
                            The 5000 happens to borrow most of its xerographic design from the 250, so the toner cartridges look basically identical, which is why there is probably some question, but that doesn't mean they are filled with the same stuff.
                            • kalindd
                              • Jun 2008
                              • 192
                              I had DC5000 that I putted. 3 different developing units loaded respectively with different developer/toner mix.
                              And there were: black unit from 700DCP, cyan and yellow unit from DC5000 and magenta from DC250.
                              All of them are still working fine 50 000 prints.
                              Cheers.
