Ricoh DD3334 drum getting stuck when reinstalling
  • tibbs
    • Aug 2008
    • 225
    Good day friends, i am having a problem with a ricoh DD3334 duplicator. The customer took out the drum but its getting stuck when reinstalling.
    She cant seem to get the drum back in.
    Any ideas.
    • 37651
    Re: Ricoh DD3334 drum getting stuck when reinstalling
    If the drum goes almost all the way in but stops about 0.5 inches short of making it, then either the drum itself, the drive for the drum or both are not at home position.
    If it gets stuck anywhere almost immediately to a little over half way in, then the pressing roller is in the released position at one or both ends. To correct the problem you have to push the roller back down until it latches. During normal the flanges of the drum are what push the roller back down. I had this problem at school once.
    • tibbs
      • Aug 2008
      • 225
      Thanks for the info. But i have tried pushing down the pressing roller but i have no luck in getting it down. The drum is in the lock position.
      The pressing roller does not go down even if i press it. Any othere ideas.
        • 37651
        How far in does the drum go?
        • tibbs
          • Aug 2008
          • 225
          The drum barely goes in, less than a quarter.
            • 37651
            did you try the rear end of the pressing roller?
            • GIUBOSS
              • 1437
              check the distances between the drum and the rest of the mechanisms while inserting it, if the roller is raised the drum should not come out, check for any bent metal parts.
              • tibbs
                • Aug 2008
                • 225
                No bent parts...pressing the roller front or back does not seem to make any difference. Cause the roller is hard does not go down much to the press.
                • GIUBOSS
                  • 1437
                  are you sure the pressure roller is on top? What else have you tried to do?
                    • 37651
                    I have had teachers trying to remove paper trip the release for the front end of the pressing roller.
                    • UNICORNico
                      • May 2018
                      • 308
                      ...The customer took out the drum but its getting stuck when reinstalling...
                      Interesting.
                      Could the customer have released the drum lock?
                      This would cause the Drum Unit to be rotated and not in the locking position, causing it to stumble.
                      With the Unit outside, place it on a table and try to turn the drum, if it rotates it is NOT blocked. Turn it until the drum is locked and insert it back into the device.
                      "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
