Brother C9130CW
  • Woxner
    • Jul 2011
    • 848
    [CQ] Brother C9130CW
    when printing color the color drops off and goes blank . seems one color at a time then i lose all m,c,y . i have replaced the drums and toner unit from another machine they have with no luck. If i print 5 sets of 5 pages the first set or two looks good most of the time. then color goes blank. if i do the jobs again same thing. even if i use the DF.
    Black seems to be ok.
    Thanks for your help
    Re: Brother C9130CW
    OEM Brother toner/drums?
    what is life on:
    drums
    toners
    belt
    fuser
    is it clean inside
    have you cleaned the corona wires?
    what have you done?
    do you have a manual?
    • Woxner
      • Jul 2011
      • 848
      Re: Brother C9130CW
      all new drums. it is crap toner. i have changed them out and she has done it twice. when i put the units in her other machine its ok. i am getting a manual. its got 15 k on the machine. Machine is clean. i was thinking hv dropping off or color drive unit. i also put the other machines unit in her machine with same results and put hers in to good machine. the other works fine with hers drum and toners
        Re: Brother C9130CW
        double check internal charge rollers iin ITB.. sounds like they may not be moving or belt is not locked down.
        • tsbservice
          Field tech
          • 8007
          Re: Brother C9130CW
          I'm leaning towards High-voltage Power Supply PCB ASSY. Unfortunatelly it looks like a PITA to test with their another MFC, basically doing the job 2 times.
          Just PM me if you need any documentation or FW.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4679
            Re: Brother C9130CW
            hey wox, i had this once (fortunatley don't work on many brothers) I also suspected the HVPS. Like tsb said it looked like a PIA so ended up replacing the machine. Sorry I couldn't offer more help.
