Brother DCP-L3550CDW - printing problems
  • spree
    • Jun 2012
    • 211
    Hello: Brother DCP-L3550CDW - printing problems.
    Toners and drums are NON genuine (compatible).
    Changing:
    - new drums
    - new toners
    - new transfer belt
    - new fuser unit
    some copies good, one very bad (6 copies super quality, 1 copie very bad quality).
    Do you have any idea where is problem?
  • GIUBOSS
    • 1437
    Are you having toner fusion problems, it could depend on both the fuser and the fake toner, try printing the colors individually, possibly an fw update, dry paper?
    • spree
      • Jun 2012
      • 211
      FW update - nothing happened. But I made maintenance 01 (at service menu) and 2 days still good!
      • GIUBOSS
        • 1437
        Did you raise the melting temperature?
        • spree
          • Jun 2012
          • 211
          No, only play with paper type (thick, bond, ...) - but nothing happened...
          But if I good remember I made maintenance 72, 73 - Sensitivity adjustment of density sensor
          • dalewb74
            • Feb 2018
            • 1167
            where is the paper stored? what is the environment like?
            • Gift
              • Mar 2011
              • 2459
              Try the following:
              - enable silent mode (=reduced process speed)
              - find the option"optimized fuser" in driver settings - wording might be a bit different
              It might have something to to with the toners - did you swap them with original or is it still compatible stuff?
              • spree
                • Jun 2012
                • 211
                The printer gone (customer has it). Thank you for your tips, and I hope it will be fine.
                P.S. no I only swap compatible toner (2 pieces, each from another manufacturer), and it was still the same problem.
