mfc-l5800dw jam inside (7000 code)
  • Rusty.Harris
    • Jan 2021
    • 621
    Tech in the shop working on a Brother, shows jam inside.
    Nothing found. Drum unit swapped, eject board assembly
    replaced. Still shows the jam inside.
    Tech said the SM says to replace the high voltage unit.
    Any other ideas for him before he does that. It's getting to the
    point it would be probably cheaper to toss it.
    TIA
  • tsbservice
    Field tech
    • 7973
    Re: mfc-l5800dw jam inside (7000 code)
    TIA
    What is exact jam code in maintenance mode please?
    We only replaced few main boards on this family, otherwise they are pretty solid for us.
    • Rusty.Harris
      • Jan 2021
      • 621
      I'll have to ask...the tech working on it has been in the field the last few days.
      I'm not touching it with a 10 foot pole.
      I HATE these tiny boxes with the interlocking covers. It's like trying to take apart
      a jigsaw puzzle, in the dark, with your hands behind your back.
      • dalewb74
        • Feb 2018
        • 1125
        i saw you said the eject assy was replaced. i am looking at the service manual. i haven't worked on this exact model. but the 7000 error points to the sensor. is that sensor in the eject assy you replaced? or on the copier itself?
