I have a question about a Brother MFC 7340, it had a squeek that I couldn't find at customers location, so I brought it back to the shop. That problem is fixed but now it jams just after the fuser ... about 1 1/2 inch out. this model has a photosensor board that accepts the thermistor input and the thermal fuse input from the fuser ... from that board, a ribbon cable connects it to the engine board. I double checked the connections and to see if the photosensor flag was tripping the sensor ... I even disconnected the ribbon cable and turned on the printer, received a fuser error !! so the ribbon is probably good !!
Could anything else be causing this ??? I had removed the High voltage power supply because I thought I had lost a screw ...
Mike @! Michael's Copier
