Designjet Flex Cables
  • theengel
    • Nov 2011
    • 1784
    Do you folks replace them?
    To me, it seems better to just go ahead and replace the whole carriage, depending on how you bill the customer. I bill by the hour for designjets, and flex cables take a while (they did every time I've attempted it, anyway). In the end, it really only has a chance of fixing the problem, yet I still have to bill for all that time.
    • 23009
    Re: Designjet Flex Cables
    If I'm going to go to the trouble, I'll do the carriage assembly. And you got a greater chance of success on the first try. =^..^=
    • Kiran Otter
      • Dec 2013
      • 1115
      Depends on the printer. The Z2100, Z3100, Z3200 and T610/T1100 carriage assemblies were changed to accommodate a new trailing cable design, so if you replace the carriage, you must also replace the trailing cable at the same time. On a Z3100 I worked on, it was going to be $1,125 to replace the trailing cable, because of the added expense of the carriage.
      The flex cables are pretty easy to replace. It's a little tedious but a lot cheaper in some cases.
      Kiran
