hp laserjet printing dirty
  • Orion2010
    • Jun 2015
    • 176
    hello to all, i have problem with hp laserjet 3015, in the front of page are white, after start to print bad, i replace 4 toner original, but the same problem appears.
  • Lance15
    • Jun 2015
    • 1088
    Re: hp laserjet printing dirty
    Looks like a fuser issue.
    • Wild Bill
      • Jul 2005
      • 774
      Agree with lance
      Izzy
        • 23006
        I see something repetitive happening there, like a fuser film. 75.5mm interval? =^..^=
        • copier tech
          • 8142
          Yes you will need to replace your fuser unit. If you were using non genuine HP, refilled or compatible cartridges these will shorten the life of your fuser unit.
          Part number is RM1-6274-020 (for 120v)
          • andyt2107
            • Jun 2013
            • 18
            Like the others say I would look at the Fuser happens on other HP's I have worked on.
            • Iowatech
              Not a service manager
              • 3930
              I will likely fall in with the rest of the people here that say there is a problem with the fusing unit, but one question first - is OEM toner being used in that machine? Sorry, issues with aftermarket toner have bit me in the sitting muscles enough times for problems like this that I had to ask.
              • andyt2107
                • Jun 2013
                • 18
                I agree our company use them tends to happen when they don't fit drum seals properly false economy in my view.
