HP laserjet 1022 double image problem
  • tamboknon
    • Sep 2015
    • 62
    Good day Sir, Im working with this printer I already replaced Fuser Assy, isolate drum cartridge, cleaned transfer roller and check all the ground contact. Anybody have encountered this problem. Please see sample print. TIA
  • Polo-022
    • Sep 2007
    • 486
    Re: HP laserjet 1022 double image problem
    Replace drum/toner cartridge
    • tamboknon
      • Sep 2015
      • 62
      Sir,I already do that replace the drum/toner cartridge. TIA
      • Polo-022
        • Sep 2007
        • 486
        First post says that you "isolated" drum module.
        By the way, never clean any transfer roller in any printer.
        How did you do that....
        • theengel
          • Nov 2011
          • 1784
          These problems are usually due to a fuser assembly... sometimes putting in an OEM is the only way to be sure. Sometimes generic ctgs will cause this. Once or twice in my life, I've seen a transfer roller cause this problem. Cleaning it won't help. You have to replace it. But my bet is generally on the fuser or the ctg.
          • theengel
            • Nov 2011
            • 1784
            Yes, but a bad ctg can create a repeat from the fuser... so it'll measure as a bad fuser, even if it's the ctg. Come to think of it, the times a transfer roller did this to me, it didn't measure as a transfer roller. I didn't actually measure it, so I don't know if it was happening in the fuser or drum, but it definitely wasn't the length for the transfer roller (they're much smaller).
            • Lance15
              • Jun 2015
              • 1089
              Like others have said. Either the fuser or toner cartridge. Are you using a genuine HP cartridge or remanufactured?
                • 23010
                Did I measure correctly? Is it about 60mm? =^..^=
                • tamboknon
                  • Sep 2015
                  • 62
                  It's a genuine drum/toner cartridge sir. TIA
                  • Lance15
                    • Jun 2015
                    • 1089
                    Do a half print test and see whether the ghosted image happens before or after the fuser. Might be a little tricky to know exactly when to open the lid going off of your picture, but, that's a sure fire way to know.
                    • tamboknon
                      • Sep 2015
                      • 62
                      Sir, It's in the drum/toner cartridge ghosted image appeared but I already replaced it with other ctg. I will try to replace it for the 3rd time. TIA
                      • theengel
                        • Nov 2011
                        • 1784
                        Your next step is to replace the transfer roller.
