HP LJ M602 99.09.67 code
  • copyman
    Owner / Technician
    • Sep 2005
    • 4789
    Looking in service manual I see 99.09.67 code is "Disk is not bootable please download firmware". Problem is when I try and download F/W with a thumb drive it looks like it is going to load then it stops and "unknown error" comes up.
    This machine was working fine until I turned it off to install a maintenance kit, when I turned it back on the 99.09.67 came up.
    Thanks for any help
  • theengel
    • Nov 2011
    • 1784
    Re: HP LJ M602 99.09.67 code
    Did anything unusual happen when you were installing the maint kit? Like did you have any reason to take off the formatter? Maybe a loose connection somewhere?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4789
      Nothing unusual when installing maint kit. Have installed many kits over the years. Only thing I did was turn off main power.
      • Lance15
        • Jun 2015
        • 1089
        Either for some reason the printer lost it's firmware residing on either the SSD or HDD (can be ordered with either -- I've mainly seen the SSD), or the SSD or HDD went bad. You can try downloading the firmware to a FAT32 formatted stick and recopy via the Preboot menu. Otherwise you'll have to replace the SSD or HDD (whichever it has).
        • copyman
          Owner / Technician
          • Sep 2005
          • 4789
          Does this machine have a HDD ? Looking at the brochure it says HDD is NOT an option? I will take a look at the service manual specs to see about hdd.
          thanks
          • mo0651
            • 1054
            Any chance you put the old fuser back in and turn back on to see if problem was a bad part?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4789
              I will try putting old fuser back in. Nothing to lose. Thanks
              • Orion2010
                • Jun 2015
                • 176
                Replace sandisk
