HP CLJ CM6040 Poor Copy Quality / Print Ok
  • 7star.tech
    • Nov 2015
    • 7
    [CQ] HP CLJ CM6040 Poor Copy Quality / Print Ok
    Hello All,
    Does anyone have solution to the poor copy quality on HP CLJ CM6040, prints from computer are ok and scans to PC are ok, only copy is poor. I have already replaced the Scanner Laser Units, but no luck.
    this seems a common issue with this model printer, I am sure most us have faced this problem at some point.
    Thanks in advance .
  • Orion2010
    • Jun 2015
    • 176
    Re: HP CLJ CM6040 Poor Copy Quality / Print Ok
    Originally posted by 7star.tech
    Hello All,
    Thanks in advance .
    go to control panel
    press copy -> more arrows -> optimize text/picture -> select PHOTOGRAPH -> OK
    • 7star.tech
      • Nov 2015
      • 7
      Originally posted by Orion2010
      go to control panel
      Thanks for the help, I have tried that and all other PQ troubleshooting options but no luck. I have replaced the scanner assembly, the laser scanner units and still no luck.
      • Lance15
        • Jun 2015
        • 1089
        Are you able to provide some pictures? It would be helpful to see the quality of the pages.
        • vodo
          • Dec 2016
          • 36
          Hello All,
          Thanks in advance .
          Test its copy quality with know GOOD MACHINE's formatter board, PN Q3938-67977.
          • 7star.tech
            • Nov 2015
            • 7
            Thanks Lance, here are the copies.
            • Lance15
              • Jun 2015
              • 1089
              Black looks to be missing.
              This document looks to be the issue your having.
              Copy Quality issue.pdf
