HP Designjet 500+ 42` Copy Quality Problem
  • mikon88
    • Mar 2011
    • 24
    [CQ] HP Designjet 500+ 42` Copy Quality Problem
    Hi , i ve got problem with HP 500+, it`s printing everything double. I ve check strip encoder and lubrication Pinch-Arm Mechanism. Carriage belt is ok . Please check attachment for exemple print. Any idea?
    I ve got fever: My English isn`t good, so please please forgive me any mistakes.
    • 23003
    Re: HP Designjet 500+ 42` Copy Quality Problem
    I'd replace the encoder strip. That's what it looks like to me.
    Have you attempted to clean the encoder? I've had some success with alcohol and a cotton pad. Anything stronger than alcohol will remove the silk-screened pattern. =^..^=
    • Lance15
      • Jun 2015
      • 1087
      Hmmmmmmmm.......
      I'd clean the encoder strip, but, my understanding is the encoder strip only tells the carriage where it's at. I noticed the Cyan printhead says Worn Out and the expiration date is 2014 as a status. Are you able to replace it?
      • theengel
        • Nov 2011
        • 1784
        I would also check the bushings on the carriage itself. You didn't take those off, did you?
        Also check the spacer at the top of the carriage.
        • Kiran Otter
          • Dec 2013
          • 1108
          The carriage bushings can definitely be the issue. When they are inserted correctly they sit flush. These do not have to be removed, ever, really.
          The first image is the carriage bushing inserted correctly. The 2nd image is the bushing inserted incorrectly. The 3rd image is the rear bushing.
          Kiran
