What a damaged encoder strip looks like from a Designjet
  • Kiran Otter
    • Dec 2013
    • 1115
    For those who haven't had this issue I thought I would share this, since I almost overlooked it myself. The damage to this encoder strip was so minor I almost didn't see it. Yet it was enough to cause paper jam messages on a HP Designjet 4500 (86.01 error.)
    Kiran
  • Lance15
    • Jun 2015
    • 1089
    Re: What a damaged encoder strip looks like from a Designjet
    Thanks Kiran! Such minor damage such as that is easily overlooked. Even smudges/finger oils can confuse a unit that uses encoder strips to detect location. I recently had a run-in with one of those DVD burner autoloaders that prints directly onto the disc once it's burnt. Looked at the encoder strip without a flashlight, you would think everything is fine. Once you get a light on the strip though, you can instantly see issues. Fingerprints and ink spray. Little piece of water dampened cloth and it started working great again!
    • Kiran Otter
      • Dec 2013
      • 1115
      Here's another from a T1700. Couldn't figure out what would leave a pattern like that but it sure made the printer unhappy. It would continue to print but make this awful clunk when the carriage would skip at that point.
      Kiran
        • 23008
        This is from a Canon iPF710. I had some difficulty getting an image ... can you see the missing marks? It's a camera view through an Eisenbach 20x magnifier.
        This is a HP Designjet 500 encoder strip that did not come clean, without losing some of the silk-screened lines.
