compatible toner
  • Daveed
    • Sep 2017
    • 3
    compatible toner
    Hi,
    There are a lot of compatible toner offered out the for the HP 4250, 4350tn. My question is whether it is better to stick with HP toner (more expensive) than to use the compatible counterparts. I also have a HP officejet pro x4756MFP and when I tried another brand the machine got really messed up. The later is an inkjet and the first one is a laserjet . I am wondering if the laserjet 4250 would be able to work as well with the compatible toner... Anyone who has tried this?
    Daveed
  • theengel
    • Nov 2011
    • 1784
    Re: compatible toner
    I use compatibles all the time. As long as you don't want perfect prints, they work fine. But then, 10 other technicians will offer ten other opinions.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      I also use compatibles.After five toners you save for new device.
        we have found that the MSE brand to be most reliable .. they even offer a warranty on their product.
        • Daveed
          • Sep 2017
          • 3
          Thanks! MSE?
          • Metrofuser
            • Sep 2017
            • 22
            Home - Liberty Laser Solutions
            We have good luck with these guys. One of the last made in the USA
            www.Metrofuser.com
            HP Printers - Parts - Printer Repair Training -Technical Support
            908-245-2100 New Jersey & California
            Five-Time Inc. 5000 Honoree
              Originally posted by Daveed
              Thanks! MSE?
              Welcome | MSE made in the USA
              • Kiran Otter
                • Dec 2013
                • 1115
                I had a HP 2600n that lasted me 10 years.. until I put Verbatim 3rd party toner cartridges in it. First the yellow one dumped toner all over the inside of the printer.. then the cyan did. So my two cents; avoid Verbatim.
                • copier tech
                  • 8172
                  Hi,
                  Daveed
                  Don't do it !
                  • copier tech
                    • 8172
                    Compatible toners ruin a perfectly servable printer.
                    HP etc spend hundreds of thousands of pounds, if not more, developing toner to ensure optimum quality & device reliability.
                    Lost count of faults I've seen over the years due to poor quality toner.
                    • Daveed
                      • Sep 2017
                      • 3
                      Hi everyone,
                      all this is very helpful. very appreciated indeed!
                      Thanks,
                      Daveed
