Designjet T790 error 01.0.10
  • musthafavi
    • Aug 2017
    • 76
    While initializing Designjet T790 plotter show up the error code 01.0:10
  • Lance15
    • Jun 2015
    • 1089
    Re: Designjet T790 error 01.0.10
    01.0.YZ
    Communication with Engine PCA failed
    The .10 part (.YZ) indicates "replace" as the Recovery Action.
    Reseat the formatter
    If no change:
    Replace the Engine PCA
    Replace the Formatter
    NOTE: For Revision B printers, the Formatter and Hard Disk are replaced as a single part.
    • Kiran Otter
      • Dec 2013
      • 1116
      I think there's a 3V battery on the formatter.. make sure it's not dead. That seems to cause odd errors.
      I had a T1100 with the same error; at first it appeared that it was the power supply, and replacing it got it to work again.. for a week. Then it did the same thing. Thinking the PSU was defective, I replaced it under warranty.. but the new one didn't get the printer working. We then tried a new Engine PCA.. and then a new formatter. The printer then worked for a week or two, and went back to the same error. I told the customer it was hopeless. I never did find out what was causing the error.
      I wish I knew what more to suggest!
      Kiran
      • musthafavi
        • Aug 2017
        • 76
        Kiran
        I forget mentioned below symptoms in my post
        LED's status in the Back
        1. ON
        2. ON
        3. Flashing
        • Kiran Otter
          • Dec 2013
          • 1116
          1. ON
          2. ON
          3. Flashing
          The manual says the part to change is the Engine PCA based on those LEDs.
          Kiran
          • musthafavi
            • Aug 2017
            • 76
            Kiran
            Could you please post service manual here
            • Kiran Otter
              • Dec 2013
              • 1116
