HP DesignJet 500 42inch
  • aco.bk
    • Sep 2012
    • 130
    Hello.I have problem with paper advance (print sample from internet ).Replaced carriage belt,Encoder Strip and paper axis motor with encoder but problem is still here.Sample is same like this.original.jpg
    Any Advice what to do with this white gap/space???
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: HP DesignJet 500 42inch
    Sounds like you ruled out the paper motor and encoder, the only other thing involved with the paper advance is the electronics module.
    Does it make any odd sounds when it advances too far? Does it ever not advance or not advance enough? I'm just curious.
    Kiran
    • aco.bk
      • Sep 2012
      • 130
      It makes sound ,,like motor rotating too fast,,....bzzzz ☺
      Sorry for bad English
        Originally posted by aco.bk
        Hello.I have problem with paper advance (print sample from internet ).Replaced carriage belt,Encoder Strip and paper axis motor with encoder but problem is still here.Sample is same like this.[ATTACH=CONFIG]38740[/ATTACH]
        what about the platen? is it driven by the paper axis?
        • Kiran Otter
          • Dec 2013
          • 1115
          My guess would be the electronics module.
          Phil; not sure sure what you mean?
          Kiran
          • aco.bk
            • Sep 2012
            • 130
            on the end it was dirty encoder.thanks a lot
            • Kiran Otter
              • Dec 2013
              • 1115
              Good catch! Usually a problem with the drive roller encoder will cause a error on startup. I also thought you meant you replaced the motor and the encoder; I see now you meant you replaced the motor with the encoder that's directly on the motor.
              Kiran
              • theengel
                • Nov 2011
                • 1784
                Never had that roller out. Damn--that looks like a job. I usually clean that encoder wheel with a wet rag while changing the encoder sensor.
