CP3525
  • tech07
    • Aug 2008
    • 409
    [Error Code] CP3525
    Getting ready to replace fuser drive to fix 59.F0. Can see its fuser drive. How long does this replcement take ? 1 hour ? 2 hours?
    How fast have you done one ? Since its my first one, should i plan on half day ?
  • theengel
    • Nov 2011
    • 1784
    Re: CP3525
    Yes
    • theengel
      • Nov 2011
      • 1784
      Re: CP3525
      Most of the time, when something goes wrong, it's because I left a connector unplugged somewhere.
      • copier tech
        • 8164
        Re: CP3525
        If this is this an HP CP3525 the fuser is a consumable item no tools needed!?
        • theengel
          • Nov 2011
          • 1784
          Re: CP3525
          Fuser drive... not fuser.
          But most of the time, you can probably get away with just replacing the solenoid without replacing the whole drive unit. There's a little panel on some of them where you can get the solenoid out and repad it. I don't know about this model. If that's the case, you won't have to take the main drive unit off--which is the suckiest part.
          • copier tech
            • 8164
            Re: CP3525
            Apologies my bad!
            Here's the service manual it may help.
            ftp://ftp.hp.com/pub/softlib/.../rp.../HP_Color_LaserJet_CP3525_Service_Manual.pdf
            • tech07
              • Aug 2008
              • 409
              Re: CP3525
              SO FAR SO GOOD.. Disassemble and install new fuser drive. 1 1/2 hours. Have not reassembled yet.
              • theengel
                • Nov 2011
                • 1784
                Re: CP3525
                Dude--hopefully, you didn't try to reassemble the next day.
                Actually--maybe that's just me. I always have a much harder time reassembling if I don't do it right away. My short-term memory is minuscule. And I'm not even a pot smoker.
                • tech07
                  • Aug 2008
                  • 409
                  Re: CP3525
                  i'll be ok. took massive amount of pictures during disassembly
                  • tech07
                    • Aug 2008
                    • 409
                    Re: CP3525
                    UPDATE : Reassembled machine. Thanks to multiple pictures I took at disassembly, I was able to reassemble in just under 2 hours. Everything went smoothly, although the new fuser drive assembly was a little tricky to put in.
                    Everything booted up fine until....50.7 fuser error. It looked like the fuser drive gear didnt quite mesh with the drive gear on the fuser. So, I took it all apart again and reinstalled. Still get 50.7. Gears still not meshing unless i push on the fuser real hard. but still get 50.7. I knew my first time for this would be challangeing but REALLY ? Any ideas guys ?
                    • Lance15
                      • Jun 2015
                      • 1089
                      Re: CP3525
                      Sounds like the fuser drive gear isn't fully seated against the chassis. Like you mentioned, it is very tricky to get it completely seated sometimes. Rotating the fuser drive motor by hand helps align the asssembly correctly and it will pop into place against the chassis.
                      • tech07
                        • Aug 2008
                        • 409
                        Re: CP3525
                        UPDATE... Total time replacing fuser drive assembly for first time....5 hours.
