hp DJ T2500 plotter
  • 1stcavvet
    • Apr 2015
    • 231
    [Misc] hp DJ T2500 plotter
    My customer tried to install his own printhead---- it came up saying Printhead replacement incomplete---I got there the black ink was bone dry, Installed a new ink and reinstalled the printhead and was rejected ----- same message. Is there some sort of work around to be able to get this new printhead to be accepted Thanks
  • Lance15
    • Jun 2015
    • 1088
    Re: hp DJ T2500 plotter
    Just watched HP's video on replacing the printhead in the T2500. Not to dis-similar from the Officejet PRO 8600 and a few DesignJet's. I guess this printhead also COMES with ink cartridges that it says MUST be used? Maybe they didn't install the ink cartridges that came with the printhead and the plotter is "stuck" thinking the printhead replacement isn't complete? Might have to order a new printhead.
    • 1stcavvet
      • Apr 2015
      • 231
      The printhead in the T2500 does not come with inks the printheads you refer to are smaller and inks are in the unit. These inks are bigger cartridges and 3 are on each side of the machine. I do think he should of had full inks before he started. but now that ink supply was restored. how do I proceed beyond this failure to complete message.
      • Lance15
        • Jun 2015
        • 1088
        Look through this attachment and see if anything helps. You may have to replace the printhead again.
        HP 727 Printhead.pdf
          • 23007
          My suggestion is to remove the roll paper and printhead manually, then power ON. When the machine calls for a printhead, follow the prompts.
          I've found that some of these plotters get stuck in an error loop, and won't recover until the printhead and paper are completely removed, then let the machine request them.
          Are they OEM ink cartridges? =^..^=
          • Kiran Otter
            • Dec 2013
            • 1109
            What Blackcat said. Also make sure the firmware is up to date; they added an incremental purge in the service menu that may help. I found more about it here:
            Designjet Update:
            HP DesignJet T9x0,... - Skills4Techs Americas | Facebook
            Kiran
            • theengel
              • Nov 2011
              • 1784
              I had a similar problem, but I can't exactly remember the symptoms. I just remember that in order to solve it, I had to install a brand new printhead with brand new inks, all at the same time. I went through the process as spelled out by the machine itself on the display panel.
