HP Laserjet P2055dn Malfunction
  • songela
    • Mar 2008
    • 216
    I have got 2 machines both misbehaving in a similar way.
    The work all fine with tray 1 in use.
    But when tray 2 is used, a second sheet is always picked which will jam before it reaches the cartridge area and sheet 1 will always come blank. I tried to verify the paper size and seems OK. The same happens when printing from either PC or Internal reports.
    I need your help please, thanks in advance!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5005
    Re: HP Laserjet P2055dn Malfunction
    It's sounds like clutch problem or maybe sticky pad on clutch solenoid.
    • Lance15
      • Jun 2015
      • 1084
      Re-pad the solenoid for tray 2. Have fun with that one. There aren't any instructions in the service manual on removing the main drive assembly.
