DesignJet Z6200 Blank Screen after replacing Trailing Cable / Ink Tube Assembly
  • KJEpps
    • Jun 2012
    • 63
    Confirmed that the printer had the reported error of 86:01 (Carriage Servo Shutdown) that wouldn't clear. During troubleshooting I noticed that there were tiny metal threads along the carriage path and then found that the Trailing Cable rubber and braided metal shield had worn off in multiple places. Came back with the Trailing Cable/Ink Supply Tube Assembly and installed it. I don't know if an HP original part would have the Ink Tube PCAs on each, but the refurbished part I got from a trusted vendor didn't have them so I had to swap them. When I powered the unit up, the first thing that happened was that the front panel was blank (lit up white background, no black rectangle) and no initialization. I shut it down and restarted. Next time, same blank screen then I started hearing a continuous trilling type beep noise, so I quickly turned it off again at the main power. I started troubleshooting the rear LED's. At power up and observing the Power Switch LEDs, I saw the amber light, it went off, then the blue light at the same time as the trilling noise, then it would cycle back to the amber light and continuously repeat this cycle. Finally, this stopped, both blue and green LEDs stayed on and the Formatter fan turned on, but still no display or other initialization. The Formatter LEDs I and II are both on. The Service Manual troubleshooting table for both those sets of LEDs doesn't list an option for Formatter LEDs I and II on plus Power Switch LEDs Blue and Green, so that is no help. I unplugged the HD and it powered up with 8 beeps, so I think I've ruled that out. I powered up with the trailing cables disconnected with no change. Leaning toward the Formatter, although it doesn't match the troubleshooting table and seems odd that this happened right after replacing other parts. Also wondering if maybe one of the Ink Tube PCA's is pulling down the Power Supply. Any help or suggestions would be greatly appreciated!
    Thanks.
    Re: DesignJet Z6200 Blank Screen after replacing Trailing Cable / Ink Tube Assembly
    Thanks.
    OK the one thing I see in all of that, You disconnected the T cable and STILL got the same issue.
    Are you sure the T cable was installed correctly and no LANS were FUBAR'd? The service manual gives a LED light pattern for errors.. and it doesn't list the pattern? strange.
    • KJEpps
      • Jun 2012
      • 63
      I reseated the connection both at the Carriage and at the Interconnect board several times. In as bad a shape as they were, I finally even tried the old Trailing Cables. No change in light patterns.
        have you re-flashed Firmware?
        could be formatter or Emod unit.
        • Kiran Otter
          • Dec 2013
          • 1109
          That 'alarm' sound is because the motherboard didn't sense the CPU fan spinning. It happens if you turn the printer off and on frequently. I find you have to turn it off, and wait a minute before turning it back on again.
          What happens if you disconnect the tube assembly cable? I would generally try disconnecting things until you get a response; trying the hard drive was a good idea. Be sure to reseat the RAM. And test the 3V battery on the motherboard. I've had that prevent these printers from booting though they did initialize, just would hang when counting down on 1.
          It's just a guess but my gut tells me it's the hard drive. The printer isn't booting far enough to initialize anything, really. If it has the funky IDE to SATA adapter on the hard drive, that has a LED on it; you can watch the hard drive activity and usually see when if it's reading the disk or not. IF there is that adapter and you see no LED, it could be the adapter itself.
          Kiran
          • KJEpps
            • Jun 2012
            • 63
            Well I went back today and tried to flash the firmware. No luck, still the blank white screen. Tried to go into Diag Mode, same thing, blank screen. Talked to HP Tech Support for authorized service providers. (We are one, but just not on Designjets, so I was surprised that they talked to me.) They confirmed what I was leaning toward - only comes as a combo for this model - Formatter/HDD. Ordered today. I'll keep you posted.
            • Kiran Otter
              • Dec 2013
              • 1109
              Odd, the parts store supplies the drive and board as separate items. I'm curious what part number it is they're sending you.
              Kiran
              • KJEpps
                • Jun 2012
                • 63
                Kiran
                This one is a B version so they gave me p/n CQ109-67044 which subs to CQ109-67052. The CQ111B uses an encrypted HD.
                • Lance15
                  • Jun 2015
                  • 1088
                  This one is a B version....
                  Looking at the exploded parts list, that's what I was thinking........
                  On this model, on the Rev A revisions, the formatter and HDD can be ordered seperately. It's EXPLICITLY listed as such in the exploded parts view. My guess was the "Encrypted Hard Disk + Formatter" was for other revisions even thought other revisions were not explicitly listed like the formatter and HDD for Rev A.
                  CQ109-67020 - Formatter (includes Processor, Heatsink & Fan)(Only for Rev A printers)
                  CQ109-67015 - Hard Disk Drive (includes Holder and screws) (Only for Rev A printers)
                  CQ109-67044 - Encrypted Hard Disk + Formatter
                  • joeh
                    • 21
                    • KJEpps
                      • Jun 2012
                      • 63
                      I don't see an interconnect board near the display, but there is one to the left of the formatter (if you're facing the back of the machine). Is that the one you're referring to?
                      I replaced the formatter/HDD combo yesterday with no change in symptoms. HP Support consulted with a higher tier of support and then suggested replacing in this order: 1. Power Supply, 2. Main Board, 3. Control Panel. So basically, they have no clue.
                      I initially talked to LPS, but the tech indicated that he wasn't familiar enough with this model to be much help.
                      How similar was the issue? I would welcome input from someone who has a clue. :-)
                      • joeh
                        • 21
                        • Kiran Otter
                          • Dec 2013
                          • 1109
                          I already sent this to OP; I needed to verify I could post it online. I didn't know this, but if you connect the power connector of the trailing cable incorrectly, you can inadvertently fry the carriage PCA and the Main PCA (the Sausalito board.) The image is cut off but went on to say the result is the display lighting up but no other progress on boot, with the green LED by the display blinking.
                          Not saying this is OP's issue, of course! But I hope this helps others avoid this mistake.
                          Kiran
                          • KJEpps
                            • Jun 2012
                            • 63
                            Kiran
                            [ATTACH=CONFIG]43935[/ATTACH]
                            Update: So I can't say whether I plugged that power connector in incorrectly, because I had reseated both cables so many times that when I rechecked, everything was plugged in properly. Since there were so many wires in the way, and I was dealing with a cramped space, I also can't rule out that I might have initially plugged it in wrong. I was able to FINALLY make progress by replacing the Main PCA and the Carriage PCA, but wait, there's more... It still wasn't fixed. Symptoms changed to 8 beeps at power up which indicates a bad hard drive. I replaced the hard drive, updated the firmware and it was FINALLY fixed. That was a relief.
                            KJ
