M525 59.05.50 ERROR
  • Wild Bill
    • Jul 2005
    • 774
    M525 59.05.50 ERROR
    Working before I replaced paper feed solenoid.
    I retraced my work, but what a pain. I also used component test and all but main motor is working. Tested my solenoids and they work also. Anyone ever have this?
    Izzy
    • 23009
    Re: M525 59.05.50 ERROR
    What happens if you unplug the paper feed solenoid? Does the main drive motor spin up? It's possible that the PF solenoid has a short to the frame ground, shorting out your 24vdc. =^..^=
    • Wild Bill
      • Jul 2005
      • 774
      Thank you for your reply Black Cat.
      Yes I actually redid the whole job looking for a short. I removed solenoid connectors and looked for a short.
      I also did the component and sensor check, things that plug into the dc controller..
      What wierd is that when I leave the toner cartridge out of machine and leave cartridge door open, when I turn it on it goes to that 59 error. Like it's stuck. I was going to try nv initialize and I also got me a new dc controller. I'll let you know. Thanks again!
      Izzy
      • Wild Bill
        • Jul 2005
        • 774
        It was the door micro switch that comes from the dc controller. When I changed the dc controller I noticed I put it in wrong. Best to remove the whole switch holder cause there i s another switch that activates at the same time when you close the toner door. Wierd that it causes this error.
        Izzy
