HP LJ 600 M602
  • aAandy
    • Apr 2012
    • 370
    HP LJ 600 M602
    hello everyone
    here's an interesting one, hopefully someone has seen this fault before and can point me in the right direction
    no motors operate either during boot, nor if you open/close the lid, nor if you attempt an internal print and so the machine displays "tray 2 lifting" ad infinitum - try an internal print using bypass and it says "printing" ad infinitum - no error codes at any time
    performed factory reset, no change
    go into diagnostics, component test and all motors & solenoids operate correctly!! so that tells me the DC controller board is OK, which i guess leaves only the formatter - i was going to return and reflash the firmware to see if that kicked it
    any suggestions?
    thanks in advance
  • Lance15
    • Jun 2015
    • 1089
    Re: HP LJ 600 M602
    I'd go into the Preboot menu and do a Partial Clean under Administrator. If that doesn't change anything, do a Clean Disk and load a fresh version of firmware.
    • aAandy
      • Apr 2012
      • 370
      Re: HP LJ 600 M602
      entered preboot, performed RAM & HDD tests OK, performed partial clean no change, formatted HDD and loaded firmware, still no change - retested all motors & solenoids in 'component test' all worked fine
      guess i'll replace the formatter and hope for the best
      • tonerjockey
        • Apr 2014
        • 567
        Re: HP LJ 600 M602
        i had that same problem before with the laserjet 4350. it was the dc controller.
        obviously a totally newer printer, but thought i'd offer my input.
        good luck, Jim
        • aAandy
          • Apr 2012
          • 370
          Re: HP LJ 600 M602
          good luck, Jim
          you could actually operate the motors in diagnostics?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4718
            Re: HP LJ 600 M602
            If you were able to test motors, etc than I would look at formatter pwb being bad
