hp m3035 scan to Email - Gateway is not responding
  • Nikola Karamanov
    • Apr 2016
    • 58
    Over port 587 I get "’smtp.gmail.com’ is a valid SMTP Gateway Server" in the web interface, But, when I try to scan and email on the printer, it says "E-mail Gateway is not responding". I was trying ports 465, 25 its says invalid smtp server. Trying with different DNS 8.8.8.8 and 8.8.4.4 no success, I've enabled "SSL Support for SMTP" and I've enabled "SMTP Authentication".
    • 8198
    Re: hp m3035 scan to Email - Gateway is not responding
    Originally posted by Nikola Karamanov
    Over port 587 I get "I've enabled "SSL Support for SMTP" and I've enabled "SMTP Authentication".
    Turn on DHCP let the machine pull the network setting & try a scan again.
    • Lance15
      • Jun 2015
      • 1089
      Had the same problem with our 3035. The thing is just TO OLD to work correctly. Turned off all scan to E-Mail access.
        • 30476
        If your device or app doesn't support SSL, you can only send mail to Gmail or G Suite users. And, you'll need to use the restricted SMTP server aspmx.l.google.com.
        On your device or app, connect to the restricted SMTP server:
        Enter aspmx.l.google.com as the server address.
        In the Port field, enter 25.
        • Lance15
          • Jun 2015
          • 1089
          Oh, didn't know anything about that address!
          It works?
            • 30476
            It works?
            Yes only to gmail accounts
            No authentication just the sender address
            • Nikola Karamanov
              • Apr 2016
              • 58
              OK, I Wll try with dhcp! That's the problem, I need to send emails not only to GMAIL users!
              • Nikola Karamanov
                • Apr 2016
                • 58
                DIDN'T WORK!
