Djz2600 lines in prints
  • digicor
    • Jul 2008
    • 1153
    This site won't let me post a pic
    But, the mk-r print head is new, ive done the print head main cycles,it got worse,
    Can there be something else to clean the print heads?
    Or another option?
    Thank u
  • Kiran Otter
    • Dec 2013
    • 1109
    Re: Djz2600 lines in prints
    Print the Diagnostic Print from the Image Quality Maintenance menu. That print should show you which printhead(s) are having issues. Compare it to page 144 of the owner's manual. http://h10032.www1.hp.com/ctg/Manual/c05171686
    If you're unsure, either scan it or take a clear picture of it and post it here. If you can't post images, put it in Dropbox and post a link, or post it on an image site like Imgur, etc.
    Kiran
    PS - Since Flash is dead, that seems to break being able to post images. Hopefully the board will get an update to fix that.
    • Kiran Otter
      • Dec 2013
      • 1109
      Ah, you can attach a file to your post using the 'Manage Attachments' button down below the message edit window.
      Kiran
      • digicor
        • Jul 2008
        • 1153
        no matter what i do the attachment just fails...
        • digicor
          • Jul 2008
          • 1153
          Kiran
          can i email you the pics?
          • digicor
            • Jul 2008
            • 1153
            according to the man, it my be the paper , i have it set to plain, which it is... but the man says there is a setting for "sensitive paper" ill try this and get back to this blog
              Or another option?
              Thank u
              take a paper towel fold it to fit in PH track
              wet with Simple Green
              park head over the paper towel.. let sit 30-40 mins
              go and clean out the service station area .. check for nicks in capping rubbers.
              remove the towel and do test prints
              works on all the major brands of inkjet based lifeforms
              • digicor
                • Jul 2008
                • 1153
                okay, fyi the service station is new, and been replaced recently..
                  are you following the SIZE guidelines? https://www.copytechnet.com/forums/faq.php
                    ok then follow my trick to clean the print heads
                    • Kiran Otter
                      • Dec 2013
                      • 1109
                      I gave the OP my email; it looks like a paper advance issue, maybe. So I recommended running the paper advance calibration for the media loaded. Still need to see the print quality diagnostic image.
                      Kiran
                      • Kiran Otter
                        • Dec 2013
                        • 1109
                        Seems running the paper advance calibration resolved the issue.
                        Kiran
                        • digicor
                          • Jul 2008
                          • 1153
                          Kiran
                          all is good
                          paper feed calibration did it
                          thank you very much
                            • 23006
                            Were there any error codes recorded?
                            • digicor
                              • Jul 2008
                              • 1153
                              52-01
                              cleaning process needed.clean the print head drop detector is all that has ever popped up
