Designjet T1100 MFP
  • Lance15
    • Jun 2015
    • 1088
    Designjet T1100 MFP
    Was called to look at this T1100 scanner that isn't pulling paper in to scan. It looks like there isn't enough downward pressure being placed on the guide plate to pull paper in. If I load paper into the front while applying slight pressure on the guide plate, it pulls paper in fine. I noticed the guide plate won't stay in the up position when I open it, so, I took the left cover off and noticed there is a piston that holds it up and it looks like it must be shot. It appears to be a generic piston with a part number of 192805 0150N, easily orderable from eBay (PNEUMATIC SPRING / Piston for Heidelberg 192805 (0150N) (HE-00-580-5037) | eBay). I'm wondering if this failed piston would cause what is happening or could there be something else wrong. Also, is there another piston on the right side? I only removed the left side. I'm attaching pictures to hopefully show what I mean.
    No pressure on the guide plate - Notice the tiny gap between the guide plate roller and entry rollers
    Slight pressure on the guide plate - The guide plate roller and entry rollers are in contact.
    Piston - Full picture
    Piston - closeup
    • 23007
    Re: Designjet T1100 MFP
    It was a different model HP Designjet ... but the problem was not the piston, it was the plastic bracket that mounts it to the frame. It was split right down the middle. Not sure about your model. =^..^=
    • Lance15
      • Jun 2015
      • 1088
      Hmmmmmmm. Not sure.
      I was also thinking that maybe squeezing the clamp shut on both sides might make for a tighter close?
      • D Hook
        • Mar 2018
        • 205
        Doesn't this model have a roller adjustment control on the top control panel?
        We had problems loading velum in ours because the paper wasn't heavy/stiff enough to trigger the mechanical sensor. Bond worked fine. Ended up having to layer the velum on top of a piece of bond to make to load ok.
        • Kiran Otter
          • Dec 2013
          • 1109
          There is a calibration for the automatic thickness adjustment control (ATAC) but if that piston is dead, I'd start with that.
          Kiran
          • Lance15
            • Jun 2015
            • 1088
            Thanks everyone. I just ordered that piston. Will reply back once installed.
            • Lance15
              • Jun 2015
              • 1088
              Got it working.
              After replacing the piston, the guide plate now stays up, but, wasn't the whole problem. By the way, if you need to replace the piston, bring a clamp! I don't know who wrote the instructions on how to install that piston in the service manual, but, they must have been on something. Your NEVER going to install it using those instructions!
              I resolved the left side not closing by removing the clamp (did both sides), cleaning off the old, crusty grease and applying new grease. A little bend here and there and it now clamps shut when pushing on the guide plate.
              As for the pickup, running the ATAC procedure did the trick!
