HP A1 Rotation
+ More Options
Posts
  • Gaffers01
    • May 2011
    • 334
    HP A1 Rotation
    I Have an issue with a Designjet T830 36" that wont rotate an A1 image to fit on the paper correctly it always prints it Portrait so there is a large portion of the page not printed on.
    So their ends up being a lot of waisted paper .
    It was doing it fine but suddenly stopped doing it, Ive tried different print drivers checked for firmware updates but still no luck
  • Kiran Otter
    • Dec 2013
    • 1106
    In the printing preferences, make sure auto rotate is turned off. Or set to zero degrees.
    Kiran
      • 22997
      Also check that your paper roll actually measures the dimensions you expect. In the past I have come across paper rolls that are 36 1/16" to 36 3/32". Those rolls will not auto size match with 36" documents. =^..^=
