HP Neverstop Laser 1001NW "won't turn on"
  • Robinh
    • 114
    [Dead] HP Neverstop Laser 1001NW "won't turn on"
    I have a customer, brought in this HP Neverstop Laser 1001NW printer. I'd never seen one before.
    Customer says they came back from vacation, tried to turn the printer on, but nothing. I pulled the covers, tested the fuse on the power supply and confirmed that I'm getting 120v to the power supply board. I removed the board and reset all the connectors, I tested the function of the interlock switch, and the keyboard. Still dead. Probably not worth fixing, not impressed with this machine, but thought I'd run it past you all...
    Thanks,
    Robin
    • 23006
    Re: HP Neverstop Laser 1001NW "won't turn on"
    Are there any of the typical outputs from the power supply board? 5vdc, +12vdc. -12vdc, 24vdc?n Any blown fuses? Can you live measure voltages to/from the fuses?
    • Robinh
      • 114
      I attempted to test the outputs, but they come off a ribbon connector and not easy to test. I have no manual or schematics, it's a small inexpensive machine. If it needs a new power supply, it's probably toast. :-(
      Thanks for the response...
      edit, and yes I have power at the fuse and up to the transformers on the PS. I looked carefully for any damaged components, and reseated all the connectors.
        • 23006
        In situations like this I try to talk the enduser out of the call. Odds are that 1 hour labor won't get them any closer to a working machine. Just bad news, and a bill.
        • Robinh
          • 114
          Yeah, it was slow or I'd have told him to chuck it in the trash.
          Just making sure I didn't miss something simple....
          • Lance15
            • Jun 2015
            • 1088
            • Robinh
              • 114
              Thanks,
              I get nothing when I attempt to turn it on.
