Designjet t1600 error 0066 0001 0059
  • Ginbolero
    • Apr 2013
    • 44
    Hi. I'm about to go look at a T1600 with an error 0066 0001 0059.
    Never seen one of these machines before, although I've worked on the T930's
    Is this a cutter error? Any pointers would be much appreciated.
    Thanks.
  • Kiran Otter
    • Dec 2013
    • 1115
    Yes, xx66 is a problem with the cutter. The cutter is part of the belt (thanks HP.) I've not had the pleasure of dealing with one, so I don't know what to look for. There's an engagement pin that sticks out of the cutter, I guess make sure that moves in and out freely. I see too there's a jig you have to use to measure the cutter placement. I've attached the adjustment instructions. Maybe it'll help.
    Hopefully there's just a strip of paper caught up in the cutter or something.
    Kiran
    • Ginbolero
      • Apr 2013
      • 44
      Thanks for that Kiran 😁 It's an odd one. It cuts in one direction, but not the other. I've ordered a new cutter and belt. I hope I don't need to do any adjustments, 'cos that looks very confusing 🤔
      Thanks for your time. I'll post back after I've fitted the new cutter.
        • 23008
        This is a common symptom of a dull or broken cutter, also cutting part-way across the page then stopping.
