HP DesignJet T830 - not detecting paper
  • Kiran Otter
    • Dec 2013
    • 1106
    Re: HP DesignJet T830 - not detecting paper
    I had a lot of trouble getting a printer to enter the extended support menu. You press HOME, BACK, HOME, HOME. But the trick is these touch-sensitive buttons are not illuminated so it's a bit tricky to know where to press. It also seemed like they didn't respond unless I tapped just above where the icon is on the panel. It took me way too long the last time I did it and I felt like an idiot. From top to bottom to the left of the display is HOME, HELP, and BACK. See the attachment.
    You'll want to reset the PMK2 counter because otherwise it will nag you when the usage eclipses.
    Kiran
    • red fuerte
      • Aug 2024
      • 2
      Tried all the solutions here but none worked. It says all sources not ready. Replaced the paper sensor but won't pull or load the roll. Won't detect from multi sheet tray either. Reseated all the cables.
      This gallery has 1 photos.
      • red fuerte
        • Aug 2024
        • 2
          • 22996
          #19
          Please be specific. What have you done?
          • Kiran Otter
            • Dec 2013
            • 1106
            #20
            If you've ruled out the sensor then you need to replace the "Bundle Board" that it plugs into.
            Kiran
