Could anyone identify this Transfer Belt?
  • patterson70
    • May 2010
    • 599
    Hello, I mislabeled this used Transfer Belt and now I don't know what it belongs to. Argh!
    Does anyone recognize which Brand or model it is for? HP?
    • 23008
    Re: Could anyone identify this Transfer Belt?
    Definitely Konica Minolta. Maybe C360, maybe 4e series. If you look at the serial # tag on the belt unit the first four digits should represent the model number. =^..^=
    • patterson70
      • May 2010
      • 599
      Thank you Mr. Cat!
      • Hansoon
        • Sep 2007
        • 3385
        As Cat said, definitely KonicaMinolta but likely for the older color series such as the BH-C-253/353 since it has the large metal tab at the left to hold it when installing.
        Hans
        • patterson70
          • May 2010
          • 599
          Originally posted by Hansoon
          As Cat said, definitely Konica Minolta but likely for the older color series such as the BH-C-253/353 since it has the large metal tab at the left to hold it when installing.
          Hans
          Thanks, I think it's a C280.
          • Hansoon
            • Sep 2007
            • 3385
            Since it has a large vertical metal handle on the left side it must be for a BH-C-253/353.
            BH-C-280/360 has a very small black plastic there and the BH-C-284/364(e) again a metal handle but with a horizontal orientation.
            Personally I find it a good idea to remove that (those) picker finger(s). Sometimes they love to dig in the transfer belt. Seemingly preferable in NEW transfer belts......
            Hans
            • tsbservice
              Field tech
              • 8016
              [ATTACH=CONFIG]52306[/ATTACH]
              Hans
              Thanks for the pictures Hans.
              Side question - anyone happen to knows if transfer belt unit for BH-C-284/364(e) can be used in place of BH-C-280/360 ?
              I mean only belt itself is probably the same but I don't want to disassemble new unit I have.
              • Hansoon
                • Sep 2007
                • 3385
                tsbservice, the after market belts I have are different. The C280/360 series have a small rubber trail on each edge. The C284/364(e) are completely without and flat. Both do not fit the old C253/353.
                Cleaning blades are the same through all 253/353/280/360/284/364(e) series.
                Hans
