Image is scanning/copying different then original
  • DrinkingFromFirehose
    • Jun 2022
    • 5
    This is a HP MP LaserJet Managed E82540dn copier. While at a customers' location they showed me output from copier and scanner (document feeder) where the image output by the copier was higher (closer to the lead edge on the main scan) and to the right (closer to the back of the copier on the sub scan). Where would I look to be able to make adjustments to the image placement/location to bring it more true to the original?
    I have looked on Google and some here on copytechnet and in the service manual, no luck yet.
    Last edited by DrinkingFromFirehose; 12-20-2022, 07:27 PM. Reason: forgot to include the copier model
    • 23010
    Re: Image is scanning/copying different then original
    It might be helpful to know what model of HP that you are referring to. =^..^=
    • Lance15
      • Jun 2015
      • 1089
      In the post:
      • subaro
        • Oct 2010
        • 1274
        Ajustment is in service mode
        pin code 04082517
          • 23010
          It's there now ... but wasn't when I read it. =^..^=
