HP T830 Error Code: 0112E9AA
  • CP-1015
    • Nov 2020
    • 308
    [Error Code] HP T830 Error Code: 0112E9AA
    If it is out network it stuck booting with only hp sign. If it is in network it stucks with 0112E9AA. Can anybody help? Thanks advanced!
    • 22999
    Re: HP T830 Error Code: 0112E9AA
    Can you print directly from a laptop (not on the network)? =^..^=
    • CP-1015
      • Nov 2020
      • 308
      I didn't try, because it think it don't boot compleat.
      • Kiran Otter
        • Dec 2013
        • 1106
        You might try an OOBE reset. Power off the printer. Hold the power button for 30 seconds, then press home, back, home, home. It's under the Reset Menu.
        Kiran
        • CP-1015
          • Nov 2020
          • 308
          Power button light is on. But no funktion. I cann't switch off. On RJ45 no lights today.
          • Kiran Otter
            • Dec 2013
            • 1106
            If you press and hold the power button, it doesn't eventually turn off?
            It's sounding like you have to replace the main PCA.
            Do you have the service manual?
            Kiran
            • CP-1015
              • Nov 2020
              • 308
              Kiran
              Press an hold the button, nothing happened.
              Yes, I have the service manual.
              • CP-1015
                • Nov 2020
                • 308
                Today I visit customer again:
                - power cord is ok
                - power button turns orange as long as held down
                - on panel allways hp sign like picture - but 2 or 3 times it is blank after plugging power cord
                - no beep after connecting power cord - neither long nor 3 short
                - I don't see heartbeat LED - neither light nor flashing
                - RJ45 without any light LED
                • Kiran Otter
                  • Dec 2013
                  • 1106
                  I'd say it needs a new main PCA.
                  Kiran
                  • wav
                    • Oct 2021
                    • 284
                    Hi see i you can do a emergency fw update like on the t520 series.
                    • CP-1015
                      • Nov 2020
                      • 308
                      How to do?
                      • Kiran Otter
                        • Dec 2013
                        • 1106
                        If you can't get into the service mode, I don't think you will be able to flash the firmware. The instructions from the service manual are attached.
                        Kiran
                        • CP-1015
                          • Nov 2020
                          • 308
                          Kiran
                          I get an error on the ftp side from HP. What's my mistake?
                          • Kiran Otter
                            • Dec 2013
                            • 1106
                            I think HP shut down their FTP, or it's restricted to some kind of invite system. I got the file though, I'll PM you a link.
                            Kiran
                            • wav
                              • Oct 2021
                              • 284
                              Pm me
