HP Color Laserjet MFP M680f's with 59.00.F0 errors
  • JtechC
    • Oct 2022
    • 56
    Hello techie's,
    Hoping someone has experienced what I'm currently experiencing on a couple M680 machines.
    I currently maintain 10 M680's for a client. Three recently experienced the 59.00.F0 errors. If you've worked on the CP3525's, M570/M575's, M651's, I'm sure you've seen this before. 9 times out of 10 it's the solenoid sticking. I've performed this repair a 100 times before with perfect results by cleaning the solenoid and placing electrical tape in place of the worn pad. One out these current 3 repaired perfectly. Two have added a large amount of frustration.
    The issues are that after this repair, two have experienced constant fuser jams with the first printed sheet stopping in the transport area and the 2nd sheet stopping 2" out of the fuser. Mind you, these machines were working with the 59.00.F0 errors if the end user powered down, opened the right door and rebooted, then closed the right door upon request. No further errors until the machines sat for 2-3 days.
    My question is, did the fuser drive assembly crap out on these two when I repaired the solenoid? Or was this always a problem?
    The individual diagnostic component tests show no issues with any part.
    I have already ordered one RM1-4974, fuser drive assembly to see if that fixes one machine.
    Thanks.
    Jeff
  • JtechC
    • Oct 2022
    • 56
    Re: HP Color Laserjet MFP M680f's with 59.00.F0 errors
    Update on this:
    I replaced the fuser drive assembly without an issue. During testing, it now produces a 13.B9 error on every job from all trays. The paper feeds exactly 2" out of the fuser on every print jo, then stops. I've run the diagnostics and tested every sensor and component. Everything tests ok. So, I decided to replace the DC controller. I still have the same 13.B error.
    Feed kits are new.
    Where else should I be looking?
    This is becoming extremely frustrating.
    Jeff
    • Lance15
      • Jun 2015
      • 1089
      ANYTHING stuck in the paper delivery assembly?
      Check the right door. I've had a scrap of paper stuck in the right-door that I couldn't see unless I kinda removed parts attached to it.
      • JtechC
        • Oct 2022
        • 56
