fuser noise on HP2420
  • vedder
    • 131
    MOrning all, just wondering if anyone had any tips for this problem, I have a HP 2420 with poor copy quality due to a faulty fuser, I have replaced the fuser, but with the new fuser in it makes a loud grinding noise as if the gears are not meshing correctly, took the new one out, put old back in, no noise, spoke to the supplier who mentioned something about a "drive train" may need replacing, but looking on the parts list im a little unsure which part this is.
    Any help or advice would be much appreciated.
    Thanks in advance.
  • prntrfxr
    • 1627
    2420 grinding
    We sell a kit with the following in it. It should help you.
    (1) RU5-0377: GEAR, 28-TOOTH, FUSER DRIVE
    (1) RU5-0378: GEAR, 20-TOOTH, FUSER DRIVE
    (1) RU5-0379: GEAR, 19-TOOTH, FUSER DRIVE
    (1) RU5-0331: GEAR, FUSER, 29-TOOTH
    (1) RC1-3609: BUSHING, LOWER PRESSURE ROLLER, RIGHT
    (1) RC1-3610: BUSHING, LOWER PRESSURE ROLLER, LEFT
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • 22927
      The funny part is that the machine doesn't get really noisy until you replace the fuser. Then it sounds like it's going to jump right off the desk.
      I bought a couple of these kits from TSA and it works as advertised. Thanks, prntrfxr. =^..^=
      • vedder
        • 131
        hi guys, thanks for your help on this, I replace the drive assembly and worked a treat.
        cheers.
