hp 4250 printer metal film has a conflict
  • copyberk-jet
    • May 2025
    Hi everyone friends ,
    film sometimes gets stuck when writing
    Waiting for your help
    I wonder if fuser oil problem
    What kind of metal film'lerde oil would you recommend
  • prntrfxr
    • 1627
    Um...ok...first of all, 4250 fusers don't use fuser oil. They use a grease, but it needs to be one that can handle high heat and is not petroleum based.
    I would recommend that you just buy a high quality rebuilt one or a new one.
    • copyberk-jet
      Thank you for your interest and your first answer
      printer repair technician in a company which I have been working as
      How do you recommend a fuser oil
      Where can I find the oil, or about
        • 22930
        No, listen.
        There is no fuser oil. They stopped using that stuff on most machines many years ago. For HP fixing films they need light lubrication inside the fixing film on the heater surface. The most commonly used grease is Molycote HP-500 high temperature grease. Just Google "Molycote HP-500". It's available from almost anybody that sells HP parts.
          • 22930
          You know, it occurs to me that I don't have any idea what symptoms are present. Why do you think you need fuser oil? If you explained it above, can you re-phrase?
          • prntrfxr
            • 1627
            I assumed he was referring to the sleeve not rotating caused by grease breakdown, but if you have no idea that this fuser doesn't use oil, you have no business trying to rebuild it. That's my 2 cents, but then if he screws it up, someone else will make the money trying to fix it and the customer won't use him again (if he's a tech).
            • Yair45
              • Mar 2008
              • 21
              the HP 500 is not available in every country.
              i use the HP-300 that has the same parameters.
              • Rob Sandberg
                • 275
                Prntrfxr is right.
                Do not try to fix the fuser. Replace the fuser.
                If the printer has not been service before order a maintenance kit Q5421A and do it right the first time.
                This will allow you to also check the swing plate gear for wear.
                Rob S
