HP LJ M3035XS MFP separation pad for ADF
    • 22999
    I found an "ADF Kit" (CB414-67918) but it does not appear to include a separation pad. As far as I can tell the only way to get the separation pad is to order the whole ADF assembly
    Does anybody have a part# for the ADF separation pad? =^..^=
  • CanonHPTech
    • Apr 2007
    • 235
    Typical HP. This isn't the first time they've done that. Think they did the same thing with a couple of their other MFP's and on some of them they went back and setup a part number, but usually what HP's thought on this is, if you wear out the Sep Pad, you've exceeded the life of the ADF. I did find a site claiming that C7309-60076 (which works on the LJ 3020/3300's) saying that it fits this series. Good luck. Let us know if it fits!
    The glass maybe half full, but less is more...
    Printer + Fax + Copier = Jack Of Many Trades,
    but Master Of None
    Color Copier = Not A Color Printer
    InkJet MFP = Not A Fax Machine
    B/W Copier = Not A Press
    Finisher = Deal Closer (salesman, not accessory)
    Copier Tech = Admin's Stress Ball (Scapegoat)
    • prntrfxr
      • 1622
      separation pad is included in the ADF kit. We sell them and I made sure by opening one to look at it. The pad is grey on a blue plastic holder.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • 22999
        That's the one. The pad is so thin you could read a newpaper through it. Thanks for lookin' =^..^=
          • 22999
          I wish I had ordered it from TSA. The parts are still not here, supposed to arrive Tuesday. Out of desperation I have refitted another type of separation pad for the short term.
          My result is a little ragged, but entirely effective. I'm mostly pleased with the not-so-elegant results.
          Thanks for searching, CanonHPTech. I'll get that sep pad ordered up as a spare. =^..^=
