HP LJ 4350 Constant PJ 13.10.00
  • MrB
    • Nov 2009
    • 147
    [Jamming] HP LJ 4350 Constant PJ 13.10.00
    Can anyone please help..
    I am a Canon tech, and during an install that a customer they was going to scrap a HP LJ 4350dtnsl
    So i saved it going to the skip
    The reason is that a user cleared a PJ (With some force) and a part dropped out of it
    The part is a piece of plastic with a spring on it, and since then it always jams
    This is the part in question
    On inspection i have found the above jam code is due to Tray 2 not lifting
    I have had a good look to see where this part goes but without any success
    If anyone can help me on this, and why the tray is not lifting i would be very greatful
    • 23009
    I don't recognize the part, but I think it's unrelated. The couple times that I've come across no-lift for tray 2, it turned out to be a power supply. To be sure put your meter on the lift motor leads. If no 24vdc is present when you push in the tray, then check the 24vdc input to the engine board. If it's also absent at the engine board you can be sure.
    When you power off and unplug for 1/2 hour the power supply may reset, but will probably only lift a few times before it cuts out again. =^..^=
    • prntrfxr
      • 1622
      That looks like a piece from the paper tray. I would get a new tray if I were you. RM1-1088 is the part number. If it still doesn't lift replace the lift drive asm.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • MrB
        • Nov 2009
        • 147
        Well i have got a little further
        That part was from the tray, on the L/H side guide
        (Found out when i tried to ajusted the paper size..)
        But now the tray lifts ...YEAAA
        BUT, it constant jams now with 13.01.00
        I have tried new rollers, and it stills jams
        Having the side off it, you can see it tries to pick, and then retries, before it reports the jam code
        But works okay from tray 1 (MPT)
        Any idea will be greatful
        I have tried a cold reset, but without any success
        • prntrfxr
          • 1622
          When you watch from the rear of the printer do you see the pick-up roller trying to pick the paper? Does the paper move at all? If it doesn't, does the solenoid at the gear asm on the right side toggle to permit the gears to turn? If not replace the solenoid. Sometimes the bushing under the gear drive gets out of position or broken. This can cause this problem. If the rollers move, but it doesn't make contact with the paper, you still have a lift problem. Related either to the tray or the lift drive as it isn't bringing the paper up to reach the roller. If the paper moves, but stops it may be a gear drive related problem or an obstruction in the paper path. Sometimes the big compression spring above the pick arm gets knocked sideways and that can cause this problem.
          • MrB
            • Nov 2009
            • 147
            Well talk about being THICK ...DERRRR DOH
            I wish i let this poor thing got to the skip in the sky now
            Having looked at a working printer, and it was so easy to see why
            The Black plate that is inside the printer,that houses the pick roller it's well Broken
            The pick roller & the pick roller shaft is totally missing
            No wonder
            Should of seen it, but was was looking at the problem deeper
            Thanks anyway for all the help
            • smo989
              HP LJ 4350 Inconstant PJ 13.10.00
              I'm hoping you can help. I have a very similar issue with a Laserjet 4250. I get the 13.10 errors from tray 2 very often. When I try a test print and look at the rollers from the back of the printer, the first page will usually go through just fine. I can see the two blue rollers rotating upon themselves as they should and when it would be time for the second page to be picked from the tray, I would expect the blue roller to reverse path and engage the pick roller. This part doenst occur. I hear a couple of clicks and then it throws the error.
              Any help would be appreciated.
              • prntrfxr
                • 1622
                go to the event log and see if any other errors are present.
                • smo989
                  Sorry for the delay. Th printer was inaccessible
                  I have printed off a event log page and the last 50 errors all read
                  13.01.00 Paper Feed 1 . Paper Late Jam
                  the page count ranges from event one at 1171865 to event 50 at 1173380
                  • prntrfxr
                    • 1622
                    At this point you should remove the right front cover (yes you have to take off the formatter cover and the top cover to remove it). Put the top cover back on and connect the drive linkage to the toner door but dont screw it down. Run your tests again watching the pick-up drive work.
                    It could be:
                    Solenoid sticking
                    feed roller bushing missing or broken
                    damaged gear obstruction in the path from the tray to the registration asm
                    or a dirty sensor.
                    • smo989
                      First of all I want to thank you for taking the time to help out with this. I have about 5 of these all showing the same behavior.
                      Did as you said. Here is what I have found
                      When doing a config page, it appears that the best chance for success I have is when I take tray 2 out then put back in. I see the solenoid engage - the gear it was holding spins and the paper is picked. Everything is great. If I try to print another config page without taking tray 2 out/in I see the solenoid engage but the gear itself does not spin. I can clearly see that the solenoid has cleared the gear so it should spin an pick the paper, but it doesn't. The 13.01.00 error is then displayed on LCD. As far as I can see there are no broken teeth or anything obstructing the movement of this gear asssembly.
                      Any other thoughts would be appreciated.
                      • smo989
                        Never mind. I just bought part RM1-0034, the whole assembly. We'll see if that fixes it.
                        • prntrfxr
                          • 1622
                          These machines have known issues with lift motors failing, bushings breaking, and inside gear breaking. The tray can be defective. Additionally, there is a compression spring in the pickup assembly that sometimes turns horizontally, that can cause jamming. Labels can get stuck in the space behind the tray 1 assembly. The solenoid can be bad. The main drive gears can be bad (unlikely). So there are quite a few things that can cause these issues.
                            • 23009
                            It may help to understand the way sector gear pickup clutches work. When the pickup solenoid releases, a spring starts the sector gear to rotate ~4 teeth to engage an adjoining gear. The solenoid is immediately released, and stops the clutch after a single rotation. Sector gear pickup clutches are susceptible to 3) common problems:
                            1) The sound damping foam on the pickup solenoid can start to become sticky, delaying the release of the solenoid actuator. The clutch would then rotate two or more cycles, feeding a second or third page, causing a 13.01.00 jam.
                            2) The spring that starts the sector gear is very weak, and delicately balanced against the strength of the solenoid and the friction of the pickup shaft bearings. If the pickup shaft bearings develop additional friction, the spring cannot start the sector gear or starts it slowly. The time delay can cause 13.01.00 jams.
                            3) The keyed end of the plastic paper pickup shaft can break. When the paper pickup shaft turns, the pickup roller does not.
                            I apologize in advance for the crappy artwork. It's all I could find about the sector gear clutch:
